Hello everyone, new here, have some TPS isuess
gray
Hi, I ride A XTZ with a 900 engine, TDM carbs and TRX TCI.
My TPS is dead, (here is the thread on the super tenere forum http://www.super-tenere.net/forum/xtz75 ... fried.html )
1. where can I get one for a reasonable price? any one wants to sell one? a mikuni part number maybe? other bikes using the same TPS?
2. I have 5 wires coming from the TCI TPS connector, 3 go to the TPS, and 2 (white and light green) are not connected, does anyone know what they are for?
3. I cant get the TPS testing mode to work (open switch disconnect TPS and re connect it), any ideas? could it be because of the malfunctioning TPS? (the Y/B wire from the TCI goes to the tacho and the tacho works fine).
thank you all, I'm glad I found this forum you seem to really know the ins and outs of this bike.
- Kayla
Re: Hello everyone, new here, have some TPS isuess
You can bypass the TPS-
gray
Thank you, I did do a search on the forum before I asked my questions, and i understand that with TPS you get a beret all around and (mid range is important) and fuel economy is compromised when bypassing the TPS (I would like to avoid that if possible).
Hello mate
dunno if this helps, extract of where the wires connect on the CDI.
Lime green goes to the left, dunno about the white one...?
gray
Thanks for the diagram, where did you get it? maybe it shows where lime green goes.
Sorry mate, I meant lime green goes to the RIGHT on the diagram.
Its a copy of part of the wiring diagram out the Haynes manual.
heres the standard TRX CDI...
gray
So I guess those other 2 wires are not needed then. thank a lot.
