Hello everyone, new here, have some TPS isuess
Posted: Fri Jun 10, 2011 12:35 pm
by gray
Hi, I ride A XTZ with a 900 engine, TDM carbs and TRX TCI.
My TPS is dead, (here is the thread on the super tenere forum http://www.super-tenere.net/forum/xtz75 ... fried.html )
1. where can I get one for a reasonable price? any one wants to sell one? a mikuni part number maybe? other bikes using the same TPS?
2. I have 5 wires coming from the TCI TPS connector, 3 go to the TPS, and 2 (white and light green) are not connected, does anyone know what they are for?
3. I cant get the TPS testing mode to work (open switch disconnect TPS and re connect it), any ideas? could it be because of the malfunctioning TPS? (the Y/B wire from the TCI goes to the tacho and the tacho works fine).
thank you all, I'm glad I found this forum you seem to really know the ins and outs of this bike.
Re: Hello everyone, new here, have some TPS isuess
Posted: Fri Jun 10, 2011 3:59 pm
by Kayla
You can bypass the TPS-
:D
Posted: Fri Jun 10, 2011 9:32 pm
by gray
Thank you, I did do a search on the forum before I asked my questions, and i understand that with TPS you get a beret all around and (mid range is important) and fuel economy is compromised when bypassing the TPS (I would like to avoid that if possible).
Posted: Fri Jun 10, 2011 10:18 pm
by trixynut
Hello mate
dunno if this helps, extract of where the wires connect on the CDI.
Lime green goes to the left, dunno about the white one...?
Posted: Sat Jun 11, 2011 8:12 pm
by gray
Thanks for the diagram, where did you get it? maybe it shows where lime green goes.
Posted: Sat Jun 11, 2011 11:09 pm
by trixynut
Sorry mate, I meant lime green goes to the RIGHT on the diagram.
Its a copy of part of the wiring diagram out the Haynes manual.
heres the standard TRX CDI...
Posted: Sun Jun 12, 2011 1:06 am
by gray
So I guess those other 2 wires are not needed then. thank a lot.
