Crankcase joint
zednine
Crankcase joint
Post by zednine » Sat Jun 11, 2011 7:00 pm
Well Ive got my crank back from the reconditioner and ready to reassemble
What sealant do you reccomend for the crankcase joint ?
Can I use a silicone or should I wait till next week and get some Yamaha stuff ?
Chris
Smithers
Re: Crankcase joint
Post by Smithers » Sun Jun 12, 2011 10:54 am
Silicon is fine .... I take it you refer to the orange or black stuff that takes a bit of heat and is meant for gaskets
Marty Moose
Re: Crankcase joint
Post by Marty Moose » Sun Jun 12, 2011 2:40 pm
You want three bond.
MM
zednine
Re: Crankcase joint
Post by zednine » Sun Jun 12, 2011 3:35 pm
Smithers wrote:Silicon is fine .... I take it you refer to the orange or black stuff that takes a bit of heat and is meant for gaskets
Thanks Smithers ........... ive got some orange in stock :)
zednine
Re: Crankcase joint
Post by zednine » Sun Jun 12, 2011 3:36 pm
Marty Moose wrote:You want three bond.
MM
What is that then please .........readily available ?
Marty Moose
Re: Crankcase joint
Post by Marty Moose » Mon Jun 13, 2011 2:21 pm
Its what most factories use on cases.
