rear brake master cylinder
Posted: Wed Jul 06, 2011 2:33 am
by GQ89
I pulled the rear brake master cylinder to pieces, cleaned it, back together and now the master cylinder will not pressurise. I tried to prime it , which did not help. Any suggestions?
I did not replace the seals while it was apart $175 for the kit, but all looked fine. I suspect not.
cheers mark
Re: rear brake master cylinder
Posted: Wed Jul 06, 2011 2:56 am
by M.V.
GQ89 wrote:Any suggestions?
Patience. I haven't rebuilt the rear mc, but when I did the front MC & brake lines, it took a long time to get pressure back.
Posted: Wed Jul 06, 2011 4:41 am
by Stankflapper
Take the caliper off, place like a tyre lever or something disc thickness inbetween the pads, then hold the caliper above the m/cyl ,,then pump and bleed, keeping the caliper always above the m/cyl this will bleed the air out much,much faster and you will have a pedal in no time. :)
Posted: Wed Jul 06, 2011 8:00 am
Throw it in the bin - life is too short.
Have an ask on here or buy another from ebay for £10.
In fact, I've very porobably got one you can have for the cost of postage
Posted: Wed Jul 06, 2011 8:13 am
by Stankflapper
Throw it in my bin... My vote is there is fk all wrong with it, just not bleed properly. :cry:
Posted: Wed Jul 06, 2011 10:18 am
by GQ89
thanks for the advice all, I will try to elevate and persevere. Rear brakes are over-rated anyway.
Posted: Sat Jul 09, 2011 8:57 am
by GQ89
gravity won. All bled nicely thanks
