Engine mounting
SDN
Engine mounting
Post by SDN » Sun Jul 31, 2011 9:53 am
All set to go out for aride yesterday when i noticed the LHS engine mounting was hanging out. On closer inspection, turned out the bolt had sheared off in the head. Anyway, drilled it out a right b*stard with high tensile bolt. Turned out that the thread was 10 X 1mm and knackered. so dilled out engine mount and replaced with 10mm thread and nut.
Anyone else had an engine mount break? any ideas why? - maybe it came loose?
Re: Engine mounting
Post by Mincehead » Sun Jul 31, 2011 4:38 pm
Yep, engine must have been able to move in it`s mounts, check ALL the engine mountings points for bolt tightness. :wink:
