As there is no airbox on my TRX, just Pod filters, what should I do with the breather pipe from the head? It currently just vents to atmosphere under the tank. I don't know if I should just block it off, draining it occasionally, or something else.
Also when the engine is running, there is a bit of smoke coming from the tube, and a slight oily dribble. Is this normal? I'm thinking I might be up for a new set of valve stem seals.
Breather pipe question
- Homer
- slow codger
Re: Breather pipe question
