Mayhem
by Mayhem » Sat Aug 20, 2011 1:31 pm
When I took ownership of my Rex the fuel tap was not set correctly. In some awkward 45 degree angle so someone was fiddling.
I believe it should be pointing down? Can someone confirm this? It then faces 'on' I believe and then if I wanted reserve it would face upwards and face res. I just need to check so I don't get stranded.
I also have very little in storage under the pillion seat. I have a tool kit strapped to the inside wall but there are also a couple of clips and another elastic strap along with some shallow brackets which would seam are the corner pieces for a spare battery or something. What should be under there and what are the parts for. I am not sure if I am missing something or not.
Cheers.
by Mincehead » Sat Aug 20, 2011 2:15 pm
I removed my bracketry, I believe them to be storage for a small U lock or similar. I didn`t have Mr Yamaha`s original toolkit with my bike either.
by fung » Sun Aug 21, 2011 10:11 am
yes mate . . .brackets for a U-lock as per Mr Yamaha . . . easily removed !
Mayhem
by Mayhem » Sun Aug 21, 2011 1:53 pm
Cheers guys. They wil not be there tomorrow. Anything other secrets Hiding under there? Some funny shapes.
by Mincehead » Sun Aug 21, 2011 2:00 pm
It`s `sensible` to run a small diameter drill down the mouldings in the undertray (the lowest points), any water that might accumulate in there will then be able to find it`s way out.
BigAl-TC
by BigAl-TC » Sun Aug 21, 2011 2:10 pm
Mincehead wrote:It`s `sensible` to run a small diameter drill down the mouldings in the undertray (the lowest points), any water that might accumulate in there will then be able to find it`s way out.
Both of mine come with those drain holes standard.
Also, you can remove the two pockets that the u lock would have poked into. Two philips head screws each underneath, then make a plate to cover the holes.
Alan.
by Mincehead » Sun Aug 21, 2011 2:41 pm
The undertray moulding has no holes at the bottom of them, at least mine didn`t, it has now though.
