Can anyone tell me the size and thread of the rear brake banjobolt, as I want to fit a hydraulic brake light switch and want to order the correct part without stipping / bleeding the rear brake
Rear Brake banjo bolt
- SDN
Re: Rear Brake banjo bolt
Yamaha generically use M10 X 1.25, although saying that the rear master cylinder on a TRX is a Brembo and they tend to be M10 X 1.00.
They also seem to need a special `short` version for Brembo`s too:
http://www.demon-tweeks.co.uk/Motorcycl ... h/392/3646
I`m sure another member will be along to confirm the right thread pitch.
All those I`ve seen marketed for Yamaha, Honda and Kawasaki are M10 X 1.25, so I`ll be interested to know for sure myself.
Pretty sure its M10 x 1.25 ie nothing special or unusual.
You'll still have to strip / drain / bleed the brakes to fit the new bolt.
- SDN
thanks guys just took banjo off it is indeed M10 X1.25, brakes were ok after few pumps - result. Have now ordered banjo + cable niples to do that FCR 41 changeover
Result indeed!
Oh and if you`re wanting a hand with nipples I`m your man.
