Axial VS Radial 'spot' calipers
Posted: Wed Sep 21, 2011 2:20 am
A quick question, from my research I have found that the R1 went from axial m/c & calipers in 2003 to radial m/c & radial calipers in 2004, given the part numbers for the pistons, seals, etc are the same for both calipers, they would be essentially the same brake caliper in terms of performance, just different in mounting?
If so, we could use the 16mm Radial M/C from the 2004 R1 (which is a cast Brembo unit) & available at Partshark for $100 USD? (Or $150 if you want the lever, mounts, screws, brake light switch, et al, but not fluid reservoir)
Anybody?
Anybody?
