What diameter are the shims?
Posted: Thu Oct 06, 2011 6:57 pm
by shards
Was looking at getting a shim kit from Bike Bandit, saw their kits advertised here....
http://www.bikebandit.com/2000-yamaha-t ... =12008&t=1
So, what size ARE the TRX shims??
Thanks, Steve
Re: What diameter are the shims?
Posted: Thu Oct 06, 2011 8:31 pm
From memory the 3LD-12168-00 Yamaha shim is 9.5mm (9.48mm) diameter. The last two digits of Yamaha`s part number changes in relation to the shim thickness. :wink: . I take it you would be looking at these? :
http://www.bikebandit.com/hot-cams-valv ... =12008&t=1
I`ve not heard many good reports about HotCams camshafts, they tend to wear too quickly but their shims may be ok.
Plenty on Ebay too by the way:
http://www.ebay.co.uk/sch/i.html?_from= ... Categories
Posted: Thu Oct 06, 2011 11:36 pm
by M.V.
Yes, 9.48mm as mince says.
Hotcams are good, about $12ea over here, or there's a place here in Vic called Precision Shims that adverstise ~$5 per shim, there's probably something similar near you.
Hope that helps!
