Hose
Mayhem
Hose
Post by Mayhem » Fri Nov 04, 2011 2:10 pm
I have discovered a hose behind the cylinders that does not have a home. That is it is not connected to anything. I am not sure whether it is a breather or should be connected to something. Has anyone else got a similar feature on their bike? Will investigate further.
Re: Hose
Post by fung » Fri Nov 04, 2011 7:26 pm
:proctor:
Re: Hose
Post by Mincehead » Fri Nov 04, 2011 8:06 pm
Likely from the top of the carbs, an overflow / breather hose. :wink:
What diameter is it?
NWS870R
Re: Hose
Post by NWS870R » Fri Nov 04, 2011 11:05 pm
Check if you have an 'unoccupied' spigot on an inlet stub - could be a vac hose? Fung's right - a picture would speak volumes on this occasion :wink:
Mayhem
Re: Hose
Post by Mayhem » Sat Nov 05, 2011 3:16 pm
Sorry boys will post pictures next time.
Took it to the mechanic to check out a couple of things and it was in fact the breather hose for the carbs. Good call.
Thanks for the posts.
Re: Hose
Post by Mincehead » Sat Nov 05, 2011 5:51 pm
Yep I thought as much, the petrol vapours harden hoses over time and they do occasionally work loose, especially if you`ve been getting hands in about that area.
