2:nd gear jumps off
Posted: Sun Nov 06, 2011 2:26 pm
by Jokenr1
Hi,
I have the 1997 year T-rex and have problem with the gearbox. If i change gear from first to second in high rpm the gear jumps to neutral. This is quite frustrating everytime it occure.
I have tried to find the answer while searching the web. Has anyone else noticed the same problem with the TRX? I know the early R1 has the same problem.
Do i need i new gearbox and what will this cost me to get it repaired?
Thx.
Re: 2:nd gear jumps off
Posted: Sun Nov 06, 2011 2:54 pm
Jokenr1 wrote:Hi,
Thx.
Every now and then when i´m not firm enough, it got much better when changing to race pattern...easier to firmly push down.
Posted: Sun Nov 06, 2011 2:58 pm
As Kw says, firm pressure and a little more `patience` will normally be all that`s required. Big twins often suffer from this 1st to 2nd gear vagueness.
Learn how to use the box and the power characteristics and TRX gearboxes generally give little problems.
Were you used to inline fours before getting your TRX?
Posted: Sun Nov 06, 2011 11:27 pm
by fung
just before you change up to second, put gentle pressure under the shifter to "load' it up, then change.
Factorypro make a shifter kit, which replaces the plain bush selector arm behind the clutch basket with a roller bearing selector arm.
its a common part between fzr1000 and trx, so you need to supply the clutch cover gasket yourself, as it comes with the fzr gasket.
only heard good things about it, and it will be one of my next additions.
:rr:
Posted: Thu Feb 02, 2012 5:24 am
by Poida
fung wrote:just before you change up to second, put gentle pressure under the shifter to "load' it up, then change.
:rr:
Hello people,
I was also thinking about this mod, is there anyone on here that has done it?
What was the result?
Thanks,
Pete
Posted: Thu Feb 02, 2012 7:05 pm
by dandywarhol
I wouldn't put any pressure on it before you shift - that's probably why the box jumps in the first place - loading it puts undue wear on the selector forks.
Posted: Thu Feb 02, 2012 10:52 pm
by fung
fair enough.
i still am looking at the factorypro shift kit, but it will have to wait now i have boughtsherlocks tdm.
keep us in the loop if you try the shift kit out ok?
:rr:
Posted: Fri Feb 03, 2012 12:15 am
by ekoja
fung wrote:fair enough.
:rr:
You bought Sherlocks TDM?
Really???
have you removed the Ulysses stickers?.
