Gold spot calipers 14mm master= which brake lines??
Ritchiritch
Post by Ritchiritch » Mon Jan 02, 2012 12:05 pm
Hi. I've have recently purchased goldspot calipers from an R6 and a 14mm master. I just need to get some brake lines now but not sure which ones i need. I understand using the trx standard ones you have to turn the connections upside down or so i have read on here. Would I be needing r6 front brake lines? If yes which year ones would I be looking at to get the right length etc to fit on the trx. On eBay there seems to be almost a different brake line for every year the r6 was produced.
Any help would be appreciated
Rich :D
Re: Gold spot calipers 14mm master= which brake lihttp://wwn
Post by dixonj » Mon Jan 02, 2012 1:19 pm
Re: Gold spot calipers 14mm master= which brake lines??
Post by fung » Mon Jan 02, 2012 10:55 pm
hi ritch.
i fitted '04 R6 blues with an '04 R6 master, turned the ends on the TRX lines but dont like the twisted mess i ended up with.
i have '04 R6 lines coming from ricerocket in the uk to fit.
as my forks are thru the clamps a fair way, the 04 lines should be the right length and the right orientation.
:rr:
NWS870R
Post by NWS870R » Tue Jan 03, 2012 1:15 am
Did you not get my e-mail Rich? Just ring Hel & tell them what you're using & they'll build lines to suit (you won't find this info on their web site tho)
PM me if you get stuck & i'll get the info for you as i need to ring them about some TDR hoses i need this week :wink:
Post by fung » Tue Jan 03, 2012 2:56 am
fung wrote:hi ritch.
:rr:
my goodridge lines arrived today from JD Motorsports.
two line kit with carbon look covers and stainless ends
ref # TYA0698-2FC-CB
fitting them up next week.
:rr:
Excalibre
Post by Excalibre » Wed Jan 04, 2012 1:57 pm
If you get HEL lines you can rotate the banjo fitting to where it's needed.
I discovered this when HEL sent me a brake line that wasn't aligned correctly for my KLR650. When I phoned them to complain they told me how to rotate the banjo.
It was easy to do and I did the same thing to the HEL lines on my TRX when I changed from standard calipers to gold-spots.
Wrap some protective tape/cloth around the banjo fitting just behind the 'bump' on the hose side of the fitting. Grip the section just behind the bump firmly with some multigrips etc. Then use something like a large phillips head screwdriver through the banjo hole to rotate the end of the banjo to where you want it.
You have to be a bit careful not to mash up the heat-shrink with the multigrips, but reheating it when you've finished will shrink it back into shape.
jjmoto
Post by jjmoto » Wed Jan 04, 2012 10:06 pm
I used Venhill (uk) hoses with my blue spots, can't recommend them highly enough
Ritchiritch
Post by Ritchiritch » Wed Jan 04, 2012 10:32 pm
jjmoto wrote:I used Venhill (uk) hoses with my blue spots, can't recommend them highly enough
Which lines did you order? Trx specific, r1/r6 maybe or did you have them build you some up?
jjmoto
Post by jjmoto » Fri Jan 06, 2012 8:30 pm
Used trx specific, off ebay 66 quid stainless fittings & banjo bolts all in (front & rear) top job
Post by fung » Sun Jan 22, 2012 10:44 am
:rr:
:rr:
all done . . . woohoo
BigAl-TC
Post by BigAl-TC » Sun Jan 22, 2012 3:03 pm
I wouldn't be happy jamming the speedo cable in there mate. It's supposed to hang free then through the loop inside the low side of your fairing.
Alan.
Post by fung » Sun Jan 22, 2012 8:01 pm
sorry?
The correct route for your speedo cable IS through both ITS guidesi
Do you not have the oem bracketry on your bike?
Fung
:rr:
Post by Killerwhale » Sun Jan 22, 2012 8:05 pm
fung wrote:sorry?
Fung
:rr:
Nah, he´s right...straight back and thru the thingie on the inside of fairing
Post by fung » Sun Jan 22, 2012 8:11 pm
ok
Check out your oem handbook or manual and you may find out otherwise my friends.
Two guides, one inside lower fairing rubber and the fork bracket.
Fung
:rr:
Post by Killerwhale » Sun Jan 22, 2012 8:31 pm
fung wrote:ok
Fung
:rr:
