headstock bearing replacement
benny13
Post by benny13 » Mon Jan 30, 2012 9:13 pm
Hi lads, I'm have to replace the headstock bearings but I'm having a hell of a time trying to get out the top bearing race, there's no notch/slot to get a bar in a tip it out! :evil:
any tips?
cheers :D
Re: headstock bearing replacement
Post by Con Rod » Mon Jan 30, 2012 9:25 pm
there is a small notch at the bottom one but I am not ashamed to say I resorted to a dremmel, cut a notch out of the inner races and then pried them out
Bearing sizes are here if you need them:
http://www.trx850.com/phpBB_forum/viewt ... =37&t=7422
benny13
Post by benny13 » Mon Jan 30, 2012 9:55 pm
Con Rod wrote:there is a small notch at the bottom one but I am not ashamed to say I resorted to a dremmel, cut a notch out of the inner races and then pried them out
ah good man, cheers mate, that will help a lot!
cheers for the sizes too
Post by fung » Tue Jan 31, 2012 12:46 am
another method is to add metal with a welder to the race thus giving you purchase for the drift.
:rr:
Post by cobbadiggabuddyblooo » Tue Jan 31, 2012 10:03 am
anyone tried using a hydralic jack once the bottom one has been removed possibly using a socket the size close to the tube diameter and pressing this up to push it out... Just as an idea :?:
Post by cobbadiggabuddyblooo » Tue Jan 31, 2012 10:06 am
but then again I spose you would have to ratchet strap the frame to stop it pulling upwards :wink:
Post by alextrx850 » Tue Jan 31, 2012 10:27 am
Just what Fung said...a quick MIG weld on the bearing face both sides gives you a great purchase point ...
A pain in the arse that the Yamaha boffins didnt give a cut away like the lower race...
Not much else will work as good...
Otherwise you COULD heat the outer frame tube to expand the metal which will release the bearing race.. but you will bugger your paint, and youd have to have the frame upside down to let it fall out as you tap the outer.....
A quick MIG weld..
bagmaker
Post by bagmaker » Tue Jan 31, 2012 9:01 pm
a little mig OR tig line
More to the point the cooling weld shrinks and takes the bearing shell with it making it easier to remove.
A hundredth of a millimetre means a lot here. After a couple of quick lines the bearing will often just fall or pop out.
Try not to get the paint hot on the frame
bagger
those who can count
and those who cannot
Post by cobbadiggabuddyblooo » Wed Feb 01, 2012 8:15 am
thats great if you have a welder in your back pocket :lol:
Post by fung » Wed Feb 01, 2012 9:29 am
fair enough
most D I Y places (bunnings , coastes hire etc) will hire out an arc welder, and that will do the job.
:rr:
benny13
Post by benny13 » Wed Feb 01, 2012 11:33 am
cheers for the replys lads, good thinking
I think when I have it out I might put a cut away so if myself or anyone has to changed them again it should be easier!
Post by alextrx850 » Wed Feb 01, 2012 11:41 am
cobbadiggabuddyblooo wrote:thats great if you have a welder in your back pocket :lol:
WHA...? if youve got a six pack....[stop looking at your stomach..!] :roll:
..ive got a MIG.... 8)
Post by cobbadiggabuddyblooo » Wed Feb 01, 2012 12:40 pm
WOW those Russians will sell anything for money... stick that motor in the TRX :wink:
Post by cobbadiggabuddyblooo » Wed Feb 01, 2012 12:42 pm
and it only cost you a six pack i'm guessing vodka... COOL
Post by alextrx850 » Wed Feb 01, 2012 8:40 pm
cobbadiggabuddyblooo wrote:WOW those Russians will sell anything for money... stick that motor in the TRX :wink:
Not that kind of MIG either...!
Sounded like it from my last video footage..heh heh
