Q for those with both TDM/TRX
Posted: Thu Mar 29, 2012 10:41 am
After putting the 900 lump in the trix and doing one a bit faster run in about 17 degrees i noticed it actually runs warmer than the TRX878cc wich in turn ran a lot hotter than standard due to comp and bore.
Have you guy´s with both machine´s noticed any difference in temp on the bikes?
Re: Q for those with both TDM/TRX
Posted: Thu Mar 29, 2012 11:12 am
by fung
my 9er runs hotter than the trx.
I was guessing the smaller has between cylinders or the smaller radiator could be the culprit.
Not so sure now you say yours is a bit toasty.
878s have less between the bores too eh.
Fung
Posted: Thu Mar 29, 2012 12:18 pm
fung wrote:my 9er runs hotter than the trx.
Fung
At least less wall between combustion and waterchannels....
Good to know though you 9er is hotter, is it the same type thermostat and placed the same on 9er?
