Master Cylinder Overhaul Needed?
Posted: Tue Apr 10, 2012 3:28 am
by Dav
On the weekend I cleaned the brake pistons and changed the brake fluid to try to eliminate what had become a kind of 3 stage feel at the lever...as in the lever would move to a position, hesitate, then on to the next...with corresponding jumps in brake effect. Quite unsafe really.
With the cleaned pistons and new fluid I still have a little bit of a 2 stage feel. While bleeding the brakes the lever operated smoothly. Would this indicate a master cyclinder overhaul is needed?
Seems a simple enough job...just wondering if anyone has experienced the same and did the overhaul fix the ussue, cheers.
Re: Master Cylinder Overhaul Needed?
Posted: Tue Apr 10, 2012 4:24 am
by alextrx850
Dav wrote:On the weekend I cleaned the brake pistons and changed the brake fluid to try to eliminate what had become a kind of 3 stage feel at the lever...as in the lever would move to a position, hesitate, then on to the next...with corresponding jumps in brake effect. Quite unsafe really.
Dav, are you using the shorty levers....maybe so , but i had the same experience alebit with my short levers as they werent pushing in the middle of the master plunger pinion.....basicly jack knifeing the plunger and causing a hang up effect...my shortys were for an r6 .
fixed the prob by alloy welding an extension to the lever bracket...then , fileing back to fit.
if you DONT have an aftermarket and different model Yamaha set and made in China...dissregard my thread...
Posted: Tue Apr 10, 2012 4:35 am
by Dav
Cheers Alex...I do have aftermarket items (thundercat fitment)...will check, but they've been on for months now and the weird action is a recent development.
I might chuck the stock lever back on and see how it behaves
Posted: Tue Apr 10, 2012 4:58 am
If you have bluespots and using a R6/1 m,cylinder or need one cheap, surf around as I found a brand new one for $76 to my door from the UK.
There was some other OEM ones from Hong Kong for close to $100. By the time you pay for a kit it's good value and gives you a complete running spare (be it a little iffy) to get you by just incase or you sell it and go back to std calipers. You'll always get a good price here in OZ for your bluespots and 14mm M/C as a package.
Posted: Tue Apr 10, 2012 5:26 am
by Dav
Cobbs, am still using the stock calipers and m cyclinder. I went bluespots with the previous trx but didn't know to match the master cylinder and wasn't impressed with the wooden action
Posted: Tue Apr 10, 2012 6:14 am
Posted: Tue Apr 10, 2012 6:50 am
by foo
If you're not careful Cobba, she'll impress that wooden spoon into your face.
by M.V.
M/C rebuild is a piece of the proverbial, definitely worth it in my opinion. I think I got the kit on eBay for about $20 IIRC. I think I took some pics when I rebuilt mine, it wasn't pretty.
Another trick is to make sure your lever pivot is well greased, when the grease dries out/gums up it can affect the feel & action of the lever.
Posted: Tue Apr 10, 2012 7:57 am
by Dav
Cheers MV, I think I'll overhaul it anyway. The Haynes tinkerers manual says every 2 years so mine's over 7 x overdue
Update: I swapped back to the stock lever, no difference (the aftermarket item has a nice spur)...just waiting on the MC rebuild kit to arrive
Posted: Wed Jun 27, 2012 7:00 am
by Dav
From the grave...m/c overhaul done today finally...kedo kit...easy on-bike job (screw you Haynes!)..perfecto progressive mellow feelings
