Green Stuff
Posted: Tue Apr 10, 2012 11:24 pm
by Kenvis Repesco
On pulling apart some of the block connectors I noticed some of them have a Green residue inside them. Could anyone tell me what this is.
Re: Green Stuff
Posted: Tue Apr 10, 2012 11:31 pm
by cal
probably copper corrosion/ oxidisation if its dry
might be some sort of protective fluid/spray if its like a really thick fluid? i
Re: Green Stuff
Posted: Wed Apr 11, 2012 7:27 am
Green residue is copper oxide, the terminals need a good clean. You could use a cotton bud with a mild acid like say vinegar or lemon juice to gently lift off the oxidisation, then rinse them with water and again apply a silicon spray or contact cleaner to make sure they are dry and protected from any further `weathering`.
