Can this be right, to the best of my knowledge (and granted thats pretty limited) the discs on the 96 FZR600 are the same as on the TRX.
They have those discs on partshark for US$126.90 each. Now, even with shipping thats Chinese disc territory.
An I missing something?
(link below)
http://www.partshark.com/fiche_section_ ... &fveh=6921
Cheap OEM Discs?
- Con Rod
Cheap OEM Discs?
- M.V.
Re: Cheap OEM Discs?
Punch the part numbers into 2wheel pros, it'll tell you what else it fitsM.V. wrote: http://www.2wheelpros.com/ gives you a cross reference of what a particular part fits by punching in the part number
http://www.partshark.com/ will usually give you the best pricesShipping is ~$40 min I think though, so best to shop smart.
Hey Rod, FZR400`s and 600`s use the same discs, as do FZ750, early Fazer 600`s and the early FJ1200.
- Con Rod
thanks guys, I went back to the stock discs on mine after an unsuccessful trial of some of the Chinese ones. My stock ones are good but looking a bit tired so I am just looking at what's out there. But most likely I will re-paint the hubs on the stock discs
