G'day guys
My TRX has sprung a slight coolant leak. I thought I had holed the radiator but it seems okay. The coolant is leaking from a bolt on the left hand side of the barrels (just near the exhuast flange) when left on the side stand for a while. I've taken the bolt out, cleaned it and replaced it and it's not damaged as far as I can tell but the slow leak persists? Anyone else had this problem, or any ideas? Thanks and cheers, Rewster
Coolant leak
Re: Coolant leak
What neck of the woods you from mate... obviously from down under...
Re: Coolant leak
The 10 mm headed drain plug that sounds like.Rewster wrote:G'day guys
Does it have a soft copper washer behind it`s head, it SHOULD HAVE. You can use a soft alloy crush washer too if you can find some with a 6 mm hole through them.
Be careful to check that there are no hair line cracks spreading from the 6 mm thread across the barrel casting.
DO NOT overtighten that bolt either, with the right soft washer behind the bolt head you`ll only need to `nip` it up, some clear silicon wiped around the threads of the bolt before installing it might help seal it if the threads have been a little stretched by someone else`s over zealous tightening.
Rewster
Re: Coolant leak
Awesome, thanks for the advice. Some times it's so obvious you miss it!
