Acewell issue
Yami
Acewell issue
Post by Yami » Sun Jul 01, 2012 6:43 pm
Hi!
Got my Acewell 3251 and have started to connect the cables on the bike.
Easiest first I thought. Indicators (right and left) is ok, high beam is ok and
the Clock is connected to the batterys + and is ok.
But I have trouble with the neutral, it wont light up. Tried putting a gear in but same.
Acewell has the grey cable for the neutral and TRX has light-blue.
Acewell also says there should be a unique GND for the neutral. TRX gauge has a brown cable
with som black spots on it which seemes to be this GND but where/how to connect it.
How have you connected the neutral cables that has an Acewell?
Pic shows how wiring should be done for the neutral.
