Shock linkage dimensions needed
Homer
Post by Homer » Tue Jul 17, 2012 6:16 am
Hi all, After struggling with my rear suspension, I'm thinking about going back to the stock setup, if it will fit my modified frame.
I'm currently running a Technoflex shock with a 1200lb (yes, you read that right!) spring. Its a ferking car spring FFS. Seems the bloke who modded the frame made a pigs ear of the new linkage and the ratios are all wrong, hence needing the spring from hell. Trouble is the power of the spring is over heating the shock oil, cooking it every couple of months, requiring a rebuild.
So, what I need to know is the distance between the three holes on the stock shock linkage.
Thanks in advance.
Homer
Re: Shock linkage dimensions needed
Post by Con Rod » Tue Jul 17, 2012 8:52 am
Homer
Post by Homer » Wed Jul 18, 2012 10:44 am
Thanks Paul, unfortunately that diagram only gives the distance between two of the holes as 45mm. I really need to know the other two distances between the remaining holes. Anyone?
