yzf and trx share front wheel?
leebex
Post by leebex » Mon Aug 06, 2012 8:57 pm
Hi, sorry for all the noob questions :oops: does the trx share its front wheel with the thundercat, found a local tcat wheel with both brake discs.
cheers, Lee
Kayla
Re: yzf and trx share front wheel?
Post by Kayla » Thu Aug 09, 2012 12:17 pm
leebex wrote:Hi, sorry for all the noob questions :oops: does the trx share its front wheel with the thundercat, found a local tcat wheel with both brake discs.
cheers, Lee
No, the Thundercat wheel is different but you should be able to get it to fit with different length spacers (the wheel bearings are the same, and the disc friction surfaces are the same distance apart but the thundercat hub is slightly wider). :D
