yzf and trx share front wheel?
Posted: Mon Aug 06, 2012 8:57 pm
by leebex
Hi, sorry for all the noob questions :oops: does the trx share its front wheel with the thundercat, found a local tcat wheel with both brake discs.
cheers, Lee
Re: yzf and trx share front wheel?
Posted: Thu Aug 09, 2012 12:17 pm
by Kayla
leebex wrote:Hi, sorry for all the noob questions :oops: does the trx share its front wheel with the thundercat, found a local tcat wheel with both brake discs.
cheers, Lee
No, the Thundercat wheel is different but you should be able to get it to fit with different length spacers (the wheel bearings are the same, and the disc friction surfaces are the same distance apart but the thundercat hub is slightly wider). :D
