best way to pull the water pump
cairndog13
Post by cairndog13 » Tue Nov 20, 2012 6:59 pm
i have a slight weep coming from the water pump , i have read stories about a shim being easy to knock off when removing the pump what is the best way to pull it wihout this happening???
Re: best way to pull the water pump
Post by Mincehead » Tue Nov 20, 2012 7:01 pm
Just carefully, residual oil film will very likely hold it in place if you`re careful. :wink:
cairndog13
Post by cairndog13 » Tue Nov 20, 2012 7:20 pm
what happens it drops ? can i be fished oot with a magnet , or is it a strip down job ?
Wombat
Forum Marsupial
Post by Wombat » Wed Nov 21, 2012 5:42 am
Seems to be the season for these. Mine was leaking slightly early last week. It stopped for a whole 10 days, then this morning I notice its leaking again.
