I am having a mare fitting the new steering head bearings in my trx and wondered if you could help me out please. It used to have the open type bearings but it seems that they only do (KOSO) the new tapered types. On installation the outer race/cups will only go into the tube as far as the first machined steps will allow inside the tube, this then leaves the upper outer race about 5mm proud of the tube and the lower outer race about 2mm proud of the tube. I thought that the races should sit dead flush with the tube at the very least??
This then has a knock on effect when I put the bottom yoke and stem into the tube, as it only leaves me with enough thread for the fitment of 1 of the 2 tabbed washers.
I am totally fecked on this so any thoughts would be very welcome, I just wanna get my beauty back together again in time for the TT 2013.
Cheers.
