coolant leaking
Posted: Tue Feb 19, 2013 5:24 pm
by jamie2476
Hello everyone
please can someone give their insight into a problem on my TRX? I started the hog up for a ride and noticed coolant leaking from the right side carb, so i took off the tank and had a jolly good poke around. Looking at similar topic already posted i think it must be the hose is old or perhaps theres a blockage inside the carb, any way can i get a longer hose and just simply connect up the 2 little exits on the main, large coolant hose and bypass the carbs altogether? also would i need to block off the carb coolant inlets?
All help gladly recieved but please keep it simple!
Jamie.
Re: coolant leaking
Posted: Tue Feb 19, 2013 9:20 pm
Yep completing the coolant circuit with a length of silicon hose leads to little difference in how the bike will behave / run, unless you`re in a cold place (northern Europe).
In which case you `could` experience icing. :wink:
Re: coolant leaking
Posted: Wed Feb 20, 2013 6:23 am
by Wombat
Yeah Jamie, mine used to do that. My mechanic at the time cured it by placing a ball bearing in the warming tube and solved the problem. Also meant that the coolant couldn't complete the carb circuit but after 7 or 8 years nothing's gone wrong so there you go :wink:
BTW they often leak either coolant or oil beneath the water pump too. Use search on this site to find more info
Re: coolant leaking
Posted: Wed Feb 20, 2013 5:46 pm
by jamie2476
Hello All,
many thanks for the info, great to have this forum for assistance.
Jamie.
Re: coolant leaking
Posted: Thu Feb 21, 2013 9:26 am
by Wombat
And if you replace the carbs with FCRs those tubes become redundant
