XTZ Header Pipes on a TRX / other fuel tank for TRX poss ?
curck
Post by curck » Thu Jun 27, 2013 12:47 am
Hey all,
is it possible to use XTZ 750 header pipes on a TRX?
are there other type fuel tanks that fit the TRX ?
(damaged one should be rebuild as a tracker/scrambler)
Greetz & Respect,
curck
Re: XTZ Header Pipes on a TRX / other fuel tank for TRX poss
Post by trixynut » Thu Jun 27, 2013 10:41 am
I have seen XTZ750s fitted with TRX850 engines and they seem to use the standard exhaust system from the XTZ on the new TRX engine.
But, this is in a xtz chassi so whether an xtz pipe on a trx engine in a trx chassis will hit the frame or swingarm etc ...... ?
curck
Post by curck » Thu Jun 27, 2013 11:28 am
Thanks for your reply Trixynut.
Here there's a picture with one, but no idea if he had to mod them or not...
Greetz & Respect,
curck
Post by trixynut » Thu Jun 27, 2013 12:01 pm
It you google images of the XTZ you will see that the standard pipes do not cross over each other just after they exit the cylinders and don't sweep up so much at the back before the can, so these are not standard pipes.
Post by handsomejackuk » Thu Jun 27, 2013 10:54 pm
interesting !!!
I have XTZ engine on my MZ baghira supermoto... didnt realise they were the same...
my pipes will probably work too if you can find a set...
M.V.
Post by M.V. » Fri Jun 28, 2013 12:14 am
G'day Curck, no idea on the pipes, but one of our members here has transplanted a tank from (I think) an XJ6:
http://www.trx850.com/phpBB_forum/viewt ... 17&p=88473
A bit of digging should turn up the details that I am lacking!
Post by fung » Fri Jun 28, 2013 6:33 am
handsomejackuk wrote:interesting !!!
750 XTZ not 660 ;)
Post by handsomejackuk » Fri Jun 28, 2013 11:42 am
ahhhhh rite.... yeah i thought as well.. mine is a single not a twin, but has twin port, i thought maybe the pipes were same distance apart...
Al.
curck
Post by curck » Mon Jul 08, 2013 8:44 pm
M.V. wrote:G'day Curck, no idea on the pipes, but one of our members here has transplanted a tank from (I think) an XJ6:
Hi all,
Thanks a lot for the replies.
I've checked this link before; http://www.advrider.com/forums/showthread.php?t=714167
It's fine, but it isn't what I'm looking for.
Maybe after a paintjob it looks better, I dunno.
About the pipes of the XTZ750, they should fit, except need some mods to mount/hold the pipes.
Seat;
I've seen one with a Ducati seat, but can't find more information.
Don't know which type it comes from...
Makes a big difference I guess.
How do you name this type of seat; ?
Are there longer foot gear/break levers?
Greetz & Respect
curck
curck
Post by curck » Tue Jul 09, 2013 8:18 pm
trixynut wrote:It you google images of the XTZ you will see that the standard pipes do not cross over each other just after they exit the cylinders and don't sweep up so much at the back before the can, so these are not standard pipes.
Post by cobbadiggabuddyblooo » Wed Jul 10, 2013 4:51 am
I remember the member who picked up the Trx that had been turned into a chookie. Picked it up cheap as it wasn't running right. It had a DR400 front end fitted being a bit taller this was causing problems with the float level on the carbs. Once this was sorted , bingo , looked like a bush pig but I have no idea what mods had been done for rear travel tho..
Edit added by Mincehead who cannot post directly on this thread due to bloody stupid works puter restrictions!!!!
Some header `goodies`:
http://www.off-the-road.de/en/Other-bik ... TZ750.html
