tappet shims???
DOUBLEDECKERDOG
tappet shims???
Post by DOUBLEDECKERDOG » Fri Jul 26, 2013 7:22 pm
just checked my tappets on the trx i have just brought as i thought it was a little noisy and found that they are all generally at there limit or just over.
does anybody know or have an idea of anywhere i can get a selection of shims?
thanks again
bubbaad
Re: tappet shims???
Post by bubbaad » Fri Jul 26, 2013 7:39 pm
E-bay item number 400195861268 or Yamaha dealer.
Snod Blatter
Re: tappet shims???
Post by Snod Blatter » Fri Jul 26, 2013 8:00 pm
Most dealers will let you trade your old shims for some of theirs if they have the right ones, usually about £5 a shim. It also lets you directly compare yours to the ones on offer to make sure you get ones of the correct diameter - smaller shims seem more usual and can cause confusion.
