Leaking thermostat housing
- ricr378
I have noticed a bit of the green stuff on the engine and a closer inspection revealed what looks like a leak from the thermostat housing. Looking in the parts manual I see there is an O ring (part 93210-49046). Has anyone had a problem with the thermostat housing before? If so is it just a case of replacing the O ring?
Cheers, Rich
Cheers, Rich
- Con Rod
Re: Leaking thermostat housing
Yep I had the same problem. Took months to discover the actual cause, I was convinced it was where the water enters at the top of the head.
The O-ring is probably ok, the issue it deposits and corrosion build up.
I just dismantled it and cleaned it all up. A bit of sanding was required, then resembled it with some automotive silicone. That was 6 months ago and I have not had an issue since
- Wombat
- Forum Marsupial
Yep, same here and same solution as Paul
- fung
And a +1 from me with miss blackie.
Dismantle,clean and reassembled with a new o-ring and grey maxbond.
- ricr378
Well I know what I am doing this weekend then. Cheers guys.
Didnt you have some info on the thermostats, Fung and able to be sourced cheap at supercheap...????fung wrote:And a +1 from me with miss blackie.
- fung
Scratching his head, he says 'can't remember off the top of my. ......
Search my posts perhaps
That's cool mate.. Figured if anyone is pulling it apart I can recall on the thread you had the thermostat opening temp as a reference when replacing.(maybe 82*c) May be worth the extra couple of dollars while apart to replace this too. I thing Mark was having issues with a thermostat and you commented on this.. ...
