Leaking thermostat housing
Posted: Sun Aug 25, 2013 11:59 am
by ricr378
I have noticed a bit of the green stuff on the engine and a closer inspection revealed what looks like a leak from the thermostat housing. Looking in the parts manual I see there is an O ring (part 93210-49046). Has anyone had a problem with the thermostat housing before? If so is it just a case of replacing the O ring?
Cheers, Rich
Re: Leaking thermostat housing
Posted: Sun Aug 25, 2013 2:03 pm
by Con Rod
Yep I had the same problem. Took months to discover the actual cause, I was convinced it was where the water enters at the top of the head.
The O-ring is probably ok, the issue it deposits and corrosion build up.
I just dismantled it and cleaned it all up. A bit of sanding was required, then resembled it with some automotive silicone. That was 6 months ago and I have not had an issue since
Posted: Mon Aug 26, 2013 7:48 am
by Wombat
Yep, same here and same solution as Paul
Posted: Mon Aug 26, 2013 8:15 am
by fung
And a +1 from me with miss blackie.
Dismantle,clean and reassembled with a new o-ring and grey maxbond.
:rr:
Posted: Mon Aug 26, 2013 9:39 am
by ricr378
Well I know what I am doing this weekend then. Cheers guys.
Posted: Mon Aug 26, 2013 2:08 pm
fung wrote:And a +1 from me with miss blackie.
:rr:
Didnt you have some info on the thermostats, Fung and able to be sourced cheap at supercheap...????
Posted: Tue Aug 27, 2013 6:53 am
by fung
Scratching his head, he says 'can't remember off the top of my. ...... :-)
Search my posts perhaps ;-)
Posted: Tue Aug 27, 2013 8:57 am
That's cool mate.. Figured if anyone is pulling it apart I can recall on the thread you had the thermostat opening temp as a reference when replacing.(maybe 82*c) May be worth the extra couple of dollars while apart to replace this too. I thing Mark was having issues with a thermostat and you commented on this.. ...
