Water induced misfire
Posted: Tue Sep 17, 2013 10:04 am
Hi all
This is actually very similar to a post by Kayla in 2008, but probably makes sense to start a new one.
My TRX develops a slight misfire after it gets wet (which can sometimes get to the point when the bike will stop and needs to rest before being restarted - not very often that bad though). It IS more often when the bike's been cleaned, but as I do a 50 mile (100 mile round trip) commute on mine every day, 50 miles of rain will do it too. I've had all the fuel and vacuum pipes changed, as they were getting old, and it has new plug caps on. It does feel more like it's to do with the fuel, as the bike will do it for several days or even weeks afterwards. It also did it one day when the bike was covered in snow in the work car park. I'm going to try the tape on the leads with self amalgamating tape as was requested (in case it's electrical), but if there is water in the float bowls, how do you stop it getting in there? I've tried it on a tank of 'performance' fuel and it's marginally better, I guess because of the additives.
Thanks
Simon
Thanks
Simon
