Looking at (hardly) used Supercorsas for track use and have found a decent pair with 180/60 rear.
Currently running a 180/55 on YZF rim and can't see why a 60 profile would not suit??
Any thoughts or experience of the 60 profile anyone?
Diablo supercorsa rear size options
Re: Diablo supercorsa rear size options
http://biketrackdayshub.com/motorcycle- ... -explained
here you go, this will give you a little heads up on aspect ratios and responses to handling..
Thanks. Should have used that link after your last reference to it. Lots of useful info.
Going to try a 180/60. Sounds like I can't go too far wrong and the TRX is so stable in a straight line I am not worried about losing a bit of this stability.
Yes a brillient link with some really handy info.....As mentioned you shouldn't loose any straight line stability especially with the profile compared to a Dunlop or Bridgestone and the nature of a 60 series over a 55 aspect ratio
