fuel tap
Posted: Wed Dec 18, 2013 11:14 am
by CASS
Hi all i need a bit of help I sent away for a fuel tap repair kit the item arrived similar in appearance nowhere near the right size my question is did yamaha stick with the one design for the bike or did they do more than one ?
Re: fuel tap
Posted: Wed Dec 18, 2013 11:59 am
by Snod Blatter
As far as I know there was just the one tap, which bit isn't the right size? Was it the normal TourMax kit?
Re: fuel tap
Posted: Wed Dec 18, 2013 12:54 pm
Someone posted up a fuel tap mod around a year ago that allows you to simply modify the std tap to work like a simple one /reserve/off tap.. Maybe worth a look into and was a couple $ for a few simple parts and 5minutes work.
Re: fuel tap
Posted: Wed Dec 18, 2013 2:05 pm
by CASS
ta for replies i should have checked more before sending for it the seal with 3 holes is about half size e bay 390621480046
Re: fuel tap
Posted: Wed Dec 18, 2013 2:18 pm
by Snod Blatter
It looks alright to me in that picture, is the 3 hole piece smaller than the O ring? Also, you probably should've bought a kit with the diaphragm, that's the part that outright fails most of the time.. In my tap the three holed piece was brittle and had to be broken out though, it did weep a bit.
Re: fuel tap
Posted: Wed Dec 18, 2013 3:33 pm
by Tarwetijger
I have been told that you want the Tourmax FCK-44 kit. This one is not listed for the TRX, but for XJR1200/1300 (*) and includes the diaphragm.
Not tested by myself, but I will in time.
If I look for Tourmax and TRX, I find the FCK-22 kit, without the diaphragm.
On a dutch webshop, but you'll get the idea:
http://www.optitune.nl/benzinekraan-revisieset-fck22
http://www.optitune.nl/benzinekraan-revisieset-fck44
(*) and more:
Kawasaki GPZ 1100 1995, Kawasaki GPZ 1100 1996, Kawasaki GPZ 1100 1997, Kawasaki VN 800 Classic 1996, Kawasaki VN 800 Classic 1997, Kawasaki VN 800 Classic 1998, Kawasaki VN 800 Classic 1999, Kawasaki VN 800 Classic 2000, Kawasaki VN 800 Classic 2001, Kawasaki VN 800 Classic 2002, Kawasaki VN 800 Classic 2003, Kawasaki VN 800 Classic 2004, Kawasaki VN 800 Classic 2005, Kawasaki VN 800 Drifter 1999, Kawasaki VN 800 Drifter 2000, Kawasaki VN 800 Vulcan 1995, Kawasaki VN 800 Vulcan 1996, Kawasaki VN 800 Vulcan 1997, Kawasaki VN 800 Vulcan 1998, Kawasaki ZRX 1100 1997, Kawasaki ZRX 1100 1998, Kawasaki ZRX 1100 1999, Kawasaki ZRX 1200 2004, Kawasaki ZRX 1200 R 2001, Kawasaki ZRX 1200 R 2002, Kawasaki ZRX 1200 R 2003, Kawasaki ZRX 1200 R 2004, Kawasaki ZRX 1200 R 2005, Kawasaki ZRX 1200 R 2006, Kawasaki ZRX 1200 S 2001, Kawasaki ZRX 1200 S 2002, Kawasaki ZRX 1200 S 2003, Kawasaki ZRX 1200 S 2004, Suzuki GSF 1200 Bandit 2001, Suzuki GSF 1200 Bandit 2002, Suzuki GSF 1200 S Bandit 2001, Suzuki GSF 1200 S Bandit 2002, Suzuki GSF 1200 S Bandit 2003, Suzuki GSF 1200 S Bandit 2004, Suzuki GSF 1200 S Bandit 2005, Yamaha XJR 1200 1995, Yamaha XJR 1200 1996, Yamaha XJR 1200 1997, Yamaha XJR 1200 1998, Yamaha XJR 1300 2000, Yamaha XJR 1300 2001, Yamaha XJR 1300 2002, Yamaha XJR 1300 2003, Yamaha XJR 1300 2004, Yamaha XJR 1300 2005, Yamaha XJR 1300 2006
cobbadiggabuddyblooo wrote:Someone posted up a fuel tap mod around a year ago that allows you to simply modify the std tap to work like a simple one /reserve/off tap.. Maybe worth a look into and was a couple $ for a few simple parts and 5minutes work.
That also works of course, but I like the idea of the fuel being cut off when engine is not running. Otherwise you eniterly rely on the float (or how is it called in english) in the carb's. With another bike this thing failed once, which resulted in a carter filled with fuel and oil.
Re: fuel tap
Posted: Wed Dec 18, 2013 4:50 pm
by CASS
thanks again trouble is the illustration gives no idea of size and it is about half the diameter the diaphragm seems ok the reason i decided to change the seals is cos i ran out of fuel completely and the tap was on normal not reserve happened twice
