Brake and Clutch Levers
Andy H
Post by Andy H » Wed Nov 13, 2013 4:10 am
Does any other Yamaha motorcycle model's brake and clutch levers fit the TRX?, as I want to purchase a set but cannot find TRX specific levers. Other models suchas YZF 1000 R1, R6, XJR1300 and others have numerous varieties made for them, so, if anyone knows of a match-up, I will most appreciate it!! [-o<
M.V.
Re: Brake and Clutch Levers
Post by M.V. » Wed Nov 13, 2013 11:09 am
OTTOMH, early year model R6 levers will work, you just need an R6 clutch perch & the brake lever will bolt straight up. Early model R1 clutch perchs are the same, not sure what year until though, obviously before they moved to a radial master cylinder.
It's been covered a fair bit already, some searching should net some exact results for you.
Welcome BTW!
Adrian9912
Post by Adrian9912 » Thu Nov 14, 2013 4:00 am
If you just search for "trx850 lever" on ebay you should get many many results. Mosy of them are after market or replicated new ones, but there is also a few second hand ones. Cant get much more genuine then that. I bought a /clutch lever out of the UK last week in fact.
http://www ebay.com/itm/130854313564?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Post by fung » Thu Nov 14, 2013 10:06 am
As per my bumped post re levers, Yzf600 thundercat is a fit :-)
Post by cobbadiggabuddyblooo » Thu Nov 14, 2013 10:21 am
YAMAHA YZF600R 1994
YAMAHA TRX850 1997
YAMAHA TRX850 1999
YAMAHA YZF600R 1997
YAMAHA TRX850 1996
YAMAHA YZF600R 1995
YAMAHA YZF600R 1998
YAMAHA YZF600R 1996 CLUTCH LEVERS Part number: 3LN8391200
YAMAHA YZF1000R 2001 FRONT BRAKE LEVER Part number: 4SV8392200
YAMAHA YZF600R 1998
YAMAHA TRX850 1997
YAMAHA TRX850 1999
YAMAHA YZF600R 1997
YAMAHA YZF1000R 1998
YAMAHA YZF600R 1996
YAMAHA YZF1000R 1996
YAMAHA YZF1000R 1997
