speedo
Re: speedo
Would depend a lot on where you are.
Aussie would be klms.
I would think that whatever your country has (mph or Klmsph) your odo would be the same.
Skybone
Re: speedo
If it's marked kmh on the outer ring, then I would assume that the odo will read in km's.
IIRC, there used to be ways of converting a KMH speedo to read MPH.
- scotsy
- Location: Leigh, Lancashire and work mon-fri in Scotland
Re: speedo
Skybone wrote:If it's marked kmh on the outer ring, then I would assume that the odo will read in km's.
My TRX came with a gold coloured one of these fitted at the bottom end of the speedo cable where it fastens to the drive on the wheel
Re: speedo
i have one of those blue things if its any help... fits to the top of the speedo was onmy supermoto you can have it for a tenner....plus plost. you need to check that it is comparible with the trx speedo though... let me know...
