Test your powers of observation
Re: Test your powers of observation
Post by fung » Mon Dec 31, 2012 6:22 am
So why are the left side nuts on some van wheelnuts and left side axle spindles on some cars left hand thread then fung? 8) I'd already thought of that one................. :wink:[/quote]
to prevent them overtightening against rotation :roll:
Fung (tyre fitter in a previous life)
Post by alextrx850 » Tue Jan 01, 2013 9:07 pm
Aaaand Phesant plucker..! :lol: :laughing6: :laughing6:
Post by dandywarhol » Tue Jan 01, 2013 10:15 pm
fung wrote:So why are the left side nuts on some van wheelnuts and left side axle spindles on some cars left hand thread then fung? 8) I'd already thought of that one................. :wink:
Fung (tyre fitter in a previous life)[/quote]
Yup..............and the TRX nut is on the left side but conventional right hand thread..................................
Rod.s
Post by Rod.s » Tue Jan 01, 2013 11:52 pm
Yup..............and the TRX nut is on the left side but conventional right hand thread..................................[/quote]
If your axle is being rotated enough (shouldn't rotate at all) to impact on the (nylock!) nut, then you have some serious bearing issues.
Left handed threaded nuts on anti-clock wise rotating shafts are used to keep the nut tight :wink:
Rod.s
Post by Rod.s » Wed Jan 02, 2013 12:09 am
Incorrect, it is to stop the lug nut from coming loose and only found on flat lug nuts, normally on trucks/vans etc, that have a dramatically varying load, it's not required on modern tapered lug nuts.
Post by dandywarhol » Wed Jan 02, 2013 1:50 am
Yup - so, as long as the spacers are transposed, then there's no problem wiith the axle going in the other way from the Factory way???? :twisted:
Rod.s
Post by Rod.s » Wed Jan 02, 2013 2:12 am
dandywarhol wrote:Yup - so, as long as the spacers are transposed, then there's no problem wiith the axle going in the other way from the Factory way???? :twisted:
correct...BUT if the nut has not been tightened and is loose it will generally undo quicker if it is on the right as the movement of the axel is dynamic in the forward direction which will undo the nut, as we acceleration more than we brake. Being on the left the same dynamic load will try to tighten the nut. :wink:
Post by alextrx850 » Wed Jan 02, 2013 3:48 am
No doubt Rod has the true direction the engineers thought...in case an owner has forgotten to tighten the nut ..
Now who would do that..? =D>
Post by Killerwhale » Wed Jan 02, 2013 1:15 pm
You´re all nuts! :lol:
Post by cobbadiggabuddyblooo » Wed Jan 02, 2013 2:11 pm
I thought on the van cause its a right hand drive the left side wouldnt matter :?
Post by dandywarhol » Sat Jan 05, 2013 12:48 pm
On a van the left side nuts are often left hand threaded to ensure they don't loosen off- more of a problem the larger the distance the nut is from the axle centre.
rbaron25
Post by rbaron25 » Sat Jan 05, 2013 11:09 pm
I have a headache... Perfect opportunity down under boys to hammer into uk Jak and no one took the opportunity :roll:
I didn't see you...
Cause you didn't bloody look!
Post by cobbadiggabuddyblooo » Sun Jan 06, 2013 12:58 pm
cobbadiggabuddyblooo wrote:I thought on the van cause its a right hand drive the left side wouldnt matter :?
But I spose if it's in the northern hemisphere it would be like water spinning down a drain and goes in the other direction than here so spin the wheel 180* just like fitting the wheel upside down problem solved :wink:
Post by dandywarhol » Sun Jan 06, 2013 1:10 pm
Lol.......
Post by dandywarhol » Tue Jan 15, 2013 9:15 pm
Just to bump this (interesting) thread - the TDM Mk1 has the axle going from right to left - the Mk2 from left to right and the 900 from right to left - all basically the same setup - no it doesn't really matter a toss as long as it's tight!
