878 ARIAS 12:1 SLIPPER SKIRT PISTONS on offer
Re: 878 ARIAS 12:1 SLIPPER SKIRT PISTONS on offer
Post by cobbadiggabuddyblooo » Sun Dec 21, 2014 10:43 am
Note to self on .... CLEARANCES from Arias
Minimum exhaust ...piston/valve 1.5mm
Minimum inlet ........piston/valve. 1.5mm
Last edited by cobbadiggabuddyblooo on Thu Nov 05, 2015 10:22 am, edited 3 times in total.
Post by cobbadiggabuddyblooo » Mon Dec 22, 2014 3:16 pm
Kenny wrote:So the answer to my PM question is they will be good to go as std with the 1mm over sized valves yes?
Yes I feel radial clearance will be OK with the 1mm oversize valves.
You will always want to check your own piston/valve clearance as head gasket thickness and any material removed from head/ barrels all come into play and may differ from mine.
No issues at all with radial clearance and 1mm oversize valves with more than ample clearance.
Last edited by cobbadiggabuddyblooo on Thu Nov 05, 2015 10:26 am, edited 1 time in total.
Post by cobbadiggabuddyblooo » Fri Feb 20, 2015 11:45 am
final pair of pistons sold
Post by cobbadiggabuddyblooo » Thu Nov 05, 2015 10:45 am
Ok another order has been put inplace for 12:1 878 pistons with 1 pair sold and 1 pair left.
I got Arias to match the std TRX piston/pin/rings weight on this run of pistons so no need even think about rebalancing the crank. Just rebore and bolt in place.
I found more than ample piston/valve and radial clearance running 1mm oversize Valves and extra 0.43mm lift on the cams.
Remember Over Racing commissioned Arias to make their 12.75:1 868 pistons and they ran 2 mm oversize valves too so more than likely why clearance is not an issue. :wink:
I found squish was no issue either with 0.3 mm to spare (0.012") over the 1mm minimum spec from Arias.
Price is $670 for pistons/pin/rings/clips and shipping within Australia.
PM me if interested.
Post by davamb » Thu Nov 05, 2015 11:34 pm
Damn your timing is horrible Brian. Although I've removed it, I haven't even begun to strip the motor yet to see what's farked.
Post by cobbadiggabuddyblooo » Mon Nov 23, 2015 7:22 am
Pistons arrived today,
Still have 1 pair left.
Please don't purchase from those I have on ebay due to the extra 10% ebay charge....
Any interest from overseas buyers please contact me to avoid excessive VAT/import taxes.
Post by davamb » Mon Nov 23, 2015 7:56 am
You're doing this just to wind me up now...
Post by cobbadiggabuddyblooo » Fri Nov 27, 2015 11:06 am
Pistons provisionally sold pending future payment.
Post by cobbadiggabuddyblooo » Sat Dec 19, 2015 7:26 am
Ok I have more pistons on their way and should arrive 2-3rd week of January.
Price still $670 including shipping within Oz or $700 including shipping to the UK.
Post by cobbadiggabuddyblooo » Sun Dec 27, 2015 5:37 am
Ok I've put together another rebuild kit with the Arias pistons, 1 x new OEM Yamaha cam chain and 1 x tensioner gasket, 10 x valve guide seals, 1 x top cam cover gaskets, 4 x spare seals for the cam cover bolts and the 2 o rings for your oil filter cover.
1 x re enforced oversize 878 head gasket to suit.
There are cap head screws for the manifold clamps and std carbies ( bowl and top ) too.
All you will need is the base gasket and 2 o rings
$970 with shipping within Oz
$1000 shipped to the UK. Talk to me about a price to place on the customs dec.
I got fcr 41's and over system for sale as well
EDIT...
FCR's and Over system both sold within 2 hrs
Post by cobbadiggabuddyblooo » Tue Mar 01, 2016 2:24 am
All pistons sold once again but I should have more in approx 4 weeks so around end of the month / beginning of April.
Post by Mincehead » Sat Mar 05, 2016 1:15 pm
Nice to see you keeping all the boys happy with upgrades Brian. ;)
Post by cobbadiggabuddyblooo » Thu May 05, 2016 11:42 am
Ok Pistons have arrived a couple of weeks ago and all bar 1 pair left.
The lucky last pair and with my focus shifting elsewhere , this will be the last pair I will bring into the country.
The set with the gaskets have been sold too.
Post by cobbadiggabuddyblooo » Tue May 10, 2016 9:04 am
Last pair provisionally sold
There is a dozen hot TRX's getting around and with these Pistons fitted so to the 7 forum members who bought them, enjoy.
I purchased a couple of spare sets of rings and clips In this last order and shall keep them aside purely for a little after sales service to the forum guys.
To those who missed out.
I'm afraid fellas you'll have to do the hard yards yourself from now on and organise your own as I change my focus to other challenges.
Thanks again
SOLD
