What is acceptable oil consumption?
Re: What is acceptable oil consumption?
Post by cobbadiggabuddyblooo » Tue Mar 05, 2013 10:48 am
Go to your local supercheap auto and get whatever 10/40 semi/synth is on special. They had Shell Helix HX7 for $24 for 5L last week so I grabbed a couple of them. I've changed the oil and filter around every 3 to 4000km and use 500ml to a 1L per change at 120,000 on the clock. I very rarely find any residue metal and the oil is just starting to change colour from blow by.. A few of us lads locally round here got together and bought filters in bulk online and that was another saving if you can organise something also. :wink:
Post by alextrx850 » Tue Mar 05, 2013 11:15 am
Sounda cheap enough Cobba, but is the oil ok to use in motorcycles with a wet clutch..?
Post by cobbadiggabuddyblooo » Wed Mar 06, 2013 3:07 am
Been using it for over 75,000 km and had no issues with no slip or noise.. The good thing is I keep the oil after the change and then use that for the oil change on the car.. :lol: new filter cleans it up and I get the full life out of it...
Post by fung » Wed Mar 06, 2013 4:15 am
still keen on the 5100 motul :)
And i also use it in the car after :)
Post by davamb » Wed Mar 06, 2013 4:50 am
I've been doing the car oil thing too after I read the spec in the user manual for what oil you can use. Like Cobba, never had an issue with slip, unlike Cobba I don't bung it in my car afterwards though - perhaps I should!
Post by cobbadiggabuddyblooo » Wed Mar 06, 2013 11:14 am
Nothing really wrong if the specs on the oil are as they say. And the new car oil filter just cleans up any discolouration from blow by just starting to show so you'll easily get 7 to 10,000km for the car especially if its an old 95 ford festiva :lol: .. It,s got 240,000 on the clock too and doesn't use a drop and it clean on the stick after another 5000k's in the car and I change it at 10
Post by alextrx850 » Wed Mar 06, 2013 11:40 am
Ok, ive gotten used to the thought that the multi grade additives used in car engine oil would glaze the clutch plates in wet clutch bikes...i have used a Penrite 10-50 Gas product which suggests a motorcycle use as well....
Then Ekoja uses the oil that they run buses with...
Otherwise its the Motul 5100 and then into the cars as well.
If it works, then why not.
Post by cobbadiggabuddyblooo » Wed Mar 06, 2013 11:47 am
Prob more detergents in the desiel oil so may be more chance of slip there but Ash seems to have no dramas ...
Post by alextrx850 » Wed Mar 06, 2013 11:48 am
cobbadiggabuddyblooo wrote:Prob more detergents in the desiel oil so may be more chance of slip there but Ash seems to have no dramas ...
Ha Ha,..come to think....i havent really seen him pop any wheelies.... :lol:
