Has a under-tail exhaust ever been done?
Adrian9912
Post by Adrian9912 » Sat Feb 14, 2015 10:11 am
Has anyone ever manage to pull off a under-tail exhaust on a TRX? Something akin to what the CBR1000's had for a while or what most of the MV Augustas have.
I have been trawling through the forums and I've not seen anyone with one.
There was someone a while ago who achieved similar, however his was under the bike, not all the way to the tail. - viewtopic.php?f=6&t=2826&hilit=undertail+exhaust
Re: Has a under-tail exhaust ever been done?
Post by Killerwhale » Sat Feb 14, 2015 1:57 pm
One in oz and one in holland IIRC....pics in here somewhere....
Post by Con Rod » Sat Feb 14, 2015 1:59 pm
yes, it has been done, you can find a few examples with a google search,
The problem is getting around the swingarm. The only nice example I have seen had a single sided swingarm
emway
Post by emway » Sat Feb 14, 2015 2:08 pm
Post by Killerwhale » Sat Feb 14, 2015 2:11 pm
Nice!
I actually read that wrong, i was thinking short under engine exhaust :shock:
Adrian9912
Post by Adrian9912 » Sat Feb 14, 2015 2:44 pm
emway wrote:Image
That's exactly what I meant, is that your bike?
emway
Post by emway » Sat Feb 14, 2015 3:34 pm
First one is from CULater. The second one with the Ducati Exhaust is also dutch. But i've not seen it finished do.
I'm working myself on a short system.
emway
Post by emway » Sun Feb 15, 2015 5:39 pm
Found another french one.
Post by alextrx850 » Sun Feb 15, 2015 8:29 pm
Bought a cheap ducati 1198 end can like the one in the above photo, was looking to down size the internals and fit it to my machine.
It's a massive thing and no wonder they like to loose the weight..
Mostly my reason not to go that way was the heat problems, rear weight balance and the Trx tail storage bin.
For others, just whack on a ducati tail section and then plumb up the pipes.
Still look at the end can on my workshop wall.
Trixed
Post by Trixed » Mon Feb 16, 2015 4:43 am
http://www.google.com.au/imgres?imgurl= ... CIQMygFMAU
This is probably the hottest one u ll come across. Search Lara Croft TRX850 on you tube, you can even hear it :)
Ps. It even has a kick starter??
drix
Post by drix » Mon Feb 16, 2015 12:53 pm
This one was posted on here a while back, guy is from South Africa but can't remember his user name. Looks superb IMO...
SDN
Post by SDN » Mon Feb 16, 2015 2:15 pm
Nice work
Trendy
Post by Trendy » Sat Jun 20, 2015 11:42 pm
I got a mate to fabricate a two into one system for my trixie. Standard downpipes to the join then 50mm right up one side under the rear foot peg hanger into a wide open stubby race can. Bloody thing wouldn't run for shit and was down by 10bhp on the dyno. Parallel twins just don't have enough pressure to force the exhaust gases out a long single pipe. Not sure about twin pipes exiting at high level as I just hacked it back down to alleviate the problem.
