gear change selector shaft length.
Bluto
Post by Bluto » Mon Sep 23, 2019 9:11 pm
Hi. I bought an engine off ebay, described as a TRX. The engine code begins 4UN, and when one piston is at TDC the other is slightly behind. So far, so TRX. However, the gear selector shaft is about an inch shorter than that on my old (knackered) engine. I know 2nd generation TDMs had staggered cranks but their engine code is different. Does anyone have any ideas?
Thanks
jpe70
Re: gear change selector shaft length.
Post by jpe70 » Wed Sep 25, 2019 11:17 am
The outgoing shaft from gearbox?
Someone cut it because the locknut siezed or gearbox is knackered and it's pushed further in (if that's possible even).
Snod Blatter
Post by Snod Blatter » Wed Sep 25, 2019 10:44 pm
I know the TDM has a different gear lever setup but not sure if the shaft is any different..?
cakeman
Post by cakeman » Sat Sep 28, 2019 5:18 pm
TDM gear selector shaft is definitely shorter than the TRX one....... Had to swap them over when I fitted a TDM engine to mine.
Post by dandywarhol » Sun Sep 29, 2019 3:25 pm
Yep
Bluto
Post by Bluto » Wed Oct 02, 2019 10:51 pm
Thanks for taking the trouble to reply. I think I've figured out what the differences mean. I remember the vendor saying he had run the engine in a TDM. I assume the changes I found are those necessary to make a TRX engine work in a TDM rolling chassis. Obvious, I suppose. Wish he (the vendor) had thought to mention the changes, as it would have saved me a bit of head-scratching. It's simple enough to switch the gear lever shaft over, but I'll start it up first (once I've swapped the engine over) to see if the engine is any good or not.
