trx rev limiter
oka
trx rev limiter
same problem as peter brisbane Japanese import , 185 km top speed . 7000rpm max . help free this sluggish trx . any feedback welcome
- Greg
Hi there Oka...
Try here:
http://trx850.myfreebb.com/viewtopic.ph ... hlight=tps
This thread is from the old board and gives a pretty good schematic and a pictorial methodology (great word eh?) on how it's done...
It works !!
Try here:
It works !!
Re: trx rev limiter
There is a link in here to an ebay item wich fixes this...someone in here bought it and reported it to work just fine.oka wrote:same problem as peter brisbane Japanese import , 185 km top speed . 7000rpm max . help free this sluggish trx . any feedback welcome
(perhaps easier than the do it yourself solution!?)
- slow codger
Your bike will rev to 7000 revs, and top out at 180 KPH, less RPM with aftermarket cans on etc.
It is easy to fit, just need to remove the fairing.
Dave E.
Sarg
oka
marty
try this link. It has a review on the rex and also a paragraph on how to disconnect the limiter.
http://www.mcroadrunner.com.au/stunts/trx_aussie.htm
Cheers Marty
- slow codger
- [JP]
well..was just reading this, is 185kph the normal top speed of the TRX?
cause the other day I pushed mine a bit..and bear in mind I don´t have a clue what mods the bike has internally as it was an ex-Harris bike..
But she went quite quickly up to 140mph (about 225kph) and was still going when I had to break....
don´t ask me about what revs cause at that speed I just looked at the speed when I started to break...
PORTUGUESE MADNESS- HolerTogni
Hi [JP]!
The maximum speed according to German registration documents is 215 km/h.
Mine does approx. 220 km/h at 8.000 rpm with a transmission ratio of 17/42 (shorter than the original 17/39).
This might be "true" 200 km/h with an estimated 10% fast reading of the speedo - and that's enough for me 'cause I prefer greater acceleration than top speed.
Quickening greetings from Munich!
dfh
replace the 120/60 front tyre with a 120/70 and bugger me backward the speedo becomes accurate...Killerwhale wrote:Out in traffic the speedo shows 210kmh -ish[JP] wrote:well..was just reading this, is 185kph the normal top speed of the TRX?
On the dyno it´s 180kmh -ish
....so the speedometer is a really happy one on the TRX it seems!
DFH
Only for restricted Japanese imports. UK spec bikes (like yours) are not restricted.[JP] wrote:well..was just reading this, is 185kph the normal top speed of the TRX?
- slow codger
