What's folks think of this one?
Post by youngy » Tue May 22, 2007 12:13 pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :middle:uk
22200 miles. What's anyone think of this?
burty
Post by burty » Tue May 22, 2007 2:01 pm
Colour scheme is not to my taste, but at £750 it's good value. It's all in how it runs really. And why it was resprayed in the first place.
Full length belly pan is a bit of a rarety, I'm not sure about those footpegs allthough that's just cosmetic. Has a few of the standard mods which saves work, I guess. Hagon shocks are normally sprung for the weight of the rider which may be good if he is the same weight as you. At only 6000 miles use it should still be good anyway.
Post by youngy » Tue May 22, 2007 2:05 pm
Cheers burty. Reserve is set at £1300 - was £1600 before.
Hadn't noticed the pegs - good call!
I was thinking the paint can't be that good as it looks like it's gone through to the metal where it's been rubbed on the tank.
rathy1406
Post by rathy1406 » Wed May 23, 2007 1:14 am
At 1300 pounds this equates to $3130 aus therefore if the engine is in good nick this is an absolute bargain. Aust you are looking at anywhere from $4000 and up.
WHERE TO NOW? WHO CAN SHOW ME THE WAY
Post by Quan-Time » Wed May 23, 2007 8:03 am
i got quoted on a TRX engine, $2500 EXCHANGE.. 4k outright.. so yer, they are expensive.. and this was for a wreck, it ran, had like 60k on it, but "its a runner, good for swapping over for a dead one"..
so yer,, bargain
burty
Post by burty » Wed May 23, 2007 9:03 am
If the engine is sound then it's a good deal. Not sure it's really the bargain in the UK. I guess it depends on the quality of the paint.
If the suspension is good then I guess it saves money over buying something more original.
Tart wheels though.
Post by trixynut » Wed May 23, 2007 1:38 pm
Martin,
It looks reasonably sound to me, and good low mileage providing all is genuine (Burtys comments on why it's been sprayed). I'd check the frame has actually been resprayed, and wasn't white originally, which would mean it's a Japanese import and would be restricted (but would also have a white face tacho and KMH speedo I believe, so easy to tell): shouldn't be an import on a P plate, usually M and N plates.
Good extras which are worth a bit: I'd suggest the mods are sensible, and secondhand Ebay prices for the bits would be:
Blue spot calipers £60?
Brake lines £20?
Bellypan £50?
Rear seat cover £100?
Laser Cans £80?
Hugger £50?
Hagon Shock £200?
New-ish Pilot Powers £180 a set new?
(I've sold most of these bits in the past on ebay, or seen others sell)
You take that off the £1,300 if you get it for that, and it looks reasonable, not cheap but not expensive.
Dave
oka
Post by oka » Thu May 24, 2007 9:14 am
i can get a complete motor, with wiring looms , no carbs for 1000k .new zealand dollars ,not worth much i know . it comes with a brand new set of over racing pistons. hasnt been started for a year or so , its a black motor . any comments ?
marty
Post by marty » Thu May 24, 2007 1:53 pm
oka wrote:i can get a complete motor, with wiring looms , no carbs for 1000k .new zealand dollars ,not worth much i know . it comes with a brand new set of over racing pistons. hasnt been started for a year or so , its a black motor . any comments ?
arnt the black motors the japanese imports?
Cheers Marty
Post by Quan-Time » Fri May 25, 2007 2:05 am
white frame was japanese, silver frame was export for australia market.. Not sure about red frame / other combo.
Silver
Post by Silver » Fri May 25, 2007 7:48 am
Martin, that blue one in kent looks a better bet, i know its not your chosen colour but it looks real clean.
Dave
Dee
Post by Dee » Fri May 25, 2007 9:42 am
Quan-Time wrote:white frame was japanese, silver frame was export for australia market.. Not sure about red frame / other combo.
Was the silver frame also UK spec? Red frame I believe is also restricted Japanese import.
Silver
Post by Silver » Fri May 25, 2007 10:27 am
Silver frame (like my hair) is UK model, also silver injun, early UK models also came with KPH speedos (like mine) i changed mine to MPH as its easier to read.
Dave
Dee
Post by Dee » Fri May 25, 2007 11:42 am
Silver wrote:Silver frame (like my hair) is UK model, also silver injun, early UK models also came with KPH speedos (like mine) i changed mine to MPH as its easier to read.
Dave
I took a mate's TRX out, and like yours, his is an early UK import with KPH clocks....REALLY confusing!
Post by Jak » Fri May 25, 2007 11:46 am
Good excuse though if you get pulled :shock: "sorry officer, I must have worked it out wrong...."
Well it worked for me :oops: :lol:
