jake
by jake » Sat Jan 19, 2008 1:31 am
Ok, bikes up and running, i think its all good there, but its popping when im off the throttle and rolling. How would i go about tuning the carbie ? any useful advice ?
99 TRX850
02 GSX-R600
02 Hyosung Comet 250
by Quan-Time » Sat Jan 19, 2008 5:47 am
carb balancers, make sure it jetted correctly, and the idle is not too low.
jake
by jake » Sat Jan 19, 2008 7:26 am
how does a carb balancer work, any useful sites, etc ...
99 TRX850
02 GSX-R600
by youngy » Sat Jan 19, 2008 11:09 am
carb balancer - measures vacuum at each inlet. adjusted via a screw in between the carbs so it is the same on both. again - look in the downloads section of this site. it's all in there.
also it may be worn emulsion tubes.
by phuk72 » Sat Jan 19, 2008 12:17 pm
popping on the overrun = too rich.
Simple fix (unless your main jets are way out) is to lift the needle a notch
by youngy » Sat Jan 19, 2008 5:35 pm
too rich = worn emulsion tubes
by phuk72 » Sat Jan 19, 2008 7:50 pm
or that ^^^^
