My speedo is off
Posted: Wed May 07, 2008 12:44 pm
by jake
is there an adjustment, it shows that im going quicker then what i actually am.
Re: My speedo is off
Posted: Wed May 07, 2008 1:24 pm
by steve speed
how much quicker ?? most std speedos read about 10% higher,, the most accurate ones you enter the distance the wheel travels in one revolution
Posted: Wed May 07, 2008 3:37 pm
by slow codger
Shouldn't be any more than 10%, on the satnav the car is 3mph out at all speeds. Can you check it against one?
Posted: Thu May 08, 2008 12:44 am
by jake
well, when me and my mate were traveling at 60 (he was keeping the speed constant) my trx was showing 70ish. When we were doing 120, it was showing 170 - 180. Is there anyway to calibrate it ?
Posted: Thu May 08, 2008 9:49 am
by youngy
No, unless there is some aftermarket item that can be fitted between the drive and the head. What front tyre do you have?
Posted: Thu May 08, 2008 10:18 am
by bobtrx
How do you know his speedo is right , mate uses his GPS navigator to check his speed .
Posted: Tue May 13, 2008 5:48 am
by jake
Its off im sure of it
Posted: Tue May 13, 2008 9:34 am
by youngy
so..........what front tyre do you have?
Posted: Tue May 13, 2008 9:44 pm
by PeterGreen
jake wrote:well, when me and my mate were traveling at 60 (he was keeping the speed constant) my trx was showing 70ish. When we were doing 120, it was showing 170 - 180. Is there anyway to calibrate it ?
You sure your mate's isn't reading MPH whilst yours is reading KPH?
Posted: Tue May 13, 2008 10:38 pm
by brockzila
if its a bike in oz then its in km. they have not had mph there since the 60s/70s when they went metric.
