Grease my rear end
Slippery
Grease my rear end
Post by Slippery » Fri May 09, 2008 11:45 am
Hello World. Has anyone got any ideas as to a safe way to hold or stand the bike so i can lube the shock and links. I keep looking at the mounting point that has the unused holes in it and thinking of putting in the time to weld up some type of race stand that bolts in at that point. Sorry if its been asked before. please push me in the right direction.Slip.
steve speed
Re: Grease my rear end
Post by steve speed » Fri May 09, 2008 12:33 pm
i take the seats off get ratchet straps around the frame sling it over the beam in the workshop and hoist it up in the air just make sure it can take the load on the beam
DOBBO
Post by DOBBO » Fri May 09, 2008 1:22 pm
I did the same job as you i packed under the sidestand foot and used a small bottle jack under the alloy plate on the oppisite side.
always expect the unexpected
Post by youngy » Fri May 09, 2008 1:41 pm
I leave the bike on the sidestand and use a trolley jack under the big engine bracket on the right hand side. Changed a number of shocks and swingarms that way.
HolerTogni
Post by HolerTogni » Fri May 09, 2008 10:26 pm
Hi Slip!
:proctor:
Image Image
Jacked up greetings from Munich!
TRX 850 & Racetrack-TRiXie
neilb10000
Post by neilb10000 » Fri May 09, 2008 11:53 pm
Nice stands there Holertogni,they lift up the bike......and you can hang your shirts on them when youve finished!!!!
ingenious =D> :D
punica78
Post by punica78 » Mon May 12, 2008 11:56 am
We did it like this:
5 May 2006: Zolder
2 September 2006: Folembray
"Fortitudo. Disciplina. Constantia. Patientia. Contemptus Mortis. Amor Gloriae. Amor Victoriae!"
Post by trixynut » Mon May 12, 2008 1:00 pm
Slippy,
If you're just doing shock and link greasing, not removing the swinger, use a bit of 9mm bar through the swingaem pivot with a jack and axle stands or a pile of bricks etc.
BTW, this thread is not at all what I'd hoped for from the title: very disappointed!!
BTW2, Punica, you wanna have a word with that guy who's taking a dump in the corner of your shed!!
Post by Jak » Mon May 12, 2008 4:36 pm
trixynut wrote:BTW, this thread is not at all what I'd hoped for from the title: very disappointed!!
Ah but it got everyone's attention and therefore got replies :D Good plan LOL
