Taking off, like, real fast
Dash
Post by Dash » Fri Oct 17, 2008 11:03 am
Question: what is the best method to get the best acceleration on a TRX? :roll:
just yank it all the way to 9k and then shift? or change gears earlier? :dontknow:
so let`s hear it: how do you people sprint against other bikes or (ignorant) car drivers? :ride:
What`s that coming over the hill? Is it a T-ReX, is it a T-ReX?
Currently riding the TRX on Boris Jeltsin mode...
Re: Taking off, like, real fast
Post by phuk72 » Fri Oct 17, 2008 12:31 pm
There's no point short shifting - you want the bike in the power
Standard TRX's make power until about 8200 so that's when to change-mine makes power until about 9,400 so that's when I change up
Also, learn to do clutchless gear changes (properly) - you'll be amazed how much difference it makes in a drag race
Kayla
Post by Kayla » Fri Oct 17, 2008 12:37 pm
I tend to shift up around 8000 and by the time I'm in third either the car's a speck behind me or I'm a speck to the other bike :lol: My bike sounds nicer than theirs though :D
gregs656
Post by gregs656 » Fri Oct 17, 2008 2:15 pm
I quiet enjoy short shifting into 5th and then winding her up . . . what an awesome feeling
The Hunt Continues . . .
steve speed
Post by steve speed » Fri Oct 17, 2008 2:26 pm
as phuk says i rev it until my shift light comes on at 9000 rpm but just before that i apply some pressure on the gear change don't worry it wont shift yet ,, then as i see the light i back off the throttle just momentarily and it goes in the next gear ,,, don't do this on the down shift though ,,, use the clutch :D :D
Post by trixynut » Fri Oct 17, 2008 3:27 pm
Agree with all the above: I do clutchless upshifts now without even relly thinking about it.
Also, if you're not too mechanically sympathetic, a second gear start with a fistfull of revs and some clutch slip can often be faster than a first gear start...
..plus when you stop, you can fry an egg on the clutch cover for a tasty and nutritional snack. :D
Post by slow codger » Fri Oct 17, 2008 4:06 pm
:twisted: JATO (Jet Assisted Take Off) pack strapped to the pillion seat, engage neutral and light the blue touch paper!! No need to use clutch at all!
HolerTogni
Post by HolerTogni » Fri Oct 17, 2008 9:33 pm
Hi slow codger!
slow codger wrote: ...
You mean like this? :shock: :lol:
Surviving greetings from Munich!
TRX 850 & Racetrack-TRiXie
Dash
Post by Dash » Sat Oct 18, 2008 3:11 pm
phuk72 wrote:There's no point short shifting - you want the bike in the power
hm, ok. so how does one make a proper clutchless gear change? I`ve heard people about it but I figured it`d wreck the gearbox 8-[
Post by Killerwhale » Sat Oct 18, 2008 4:22 pm
With a quickshifter!? :)
Post by phuk72 » Sat Oct 18, 2008 4:43 pm
pressure on lever, back off power momentarily, snick into gear, T W O
steve speed
Post by steve speed » Sat Oct 18, 2008 5:36 pm
thought i just said that !!!! is nobody listening [-( [-( [-( [-( [-( [-( [-(
Dash
Post by Dash » Sat Oct 18, 2008 6:26 pm
steve speed wrote:thought i just said that !!!! is nobody listening [-( [-( [-( [-( [-( [-( [-(
not to you we`re not :roll:
[-o<
edit: but ok, it`s a simple as that huh? I`ll give it a whirl then.
steve speed
Post by steve speed » Sat Oct 18, 2008 6:38 pm
[-o<
theres somthing else you can do that will make you very fast off the mark,,, but iam [-( [-( [-( [-( [-( [-( [-( [-(
Dash
Post by Dash » Sun Oct 19, 2008 10:54 am
[-o<
oowww... don`t be cross with me. [-o<
I was only joking :roll:
but I was thinking about mounting some rockets 8)
