Kayla
by Kayla » Sat Aug 01, 2009 8:17 am
Will this mess up the power of my bike?
http://cgi.ebay.co.uk/Delkevic-TDM850-9 ... 286.c0.m14
and do you reckon it'd fit?
I'm guessing that they're the same bore as the standard TRX headers. I'm just wondering, that's all
by trixynut » Sat Aug 01, 2009 2:41 pm
As the cylinders are the same then I'd say they are bound to fit.
But you'd have to make up some pipework to connect to ths can. TRX is 2 into 2 as standard, as you know.
Kayla
by Kayla » Sat Aug 01, 2009 3:18 pm
trixynut wrote:As the cylinders are the same then I'd say they are bound to fit.
Thanks. I might give it a try when pay day comes around
Not the same as a 2-1 Akrapovic, I know
but should still save a few kg off the bike
by Killerwhale » Sat Aug 01, 2009 4:44 pm
Kayla wrote:trixynut wrote:As the cylinders are the same then I'd say they are bound to fit.
Kedo has a set for TDM wich are supposed to give +2hp at 5k something...
by Tarwetijger » Sun Aug 02, 2009 12:13 pm
I assume that you've seen the advert from Philk?
Compared to a stock TDM that is. I also thought that I've read somewhere the "bigger" diameter TDM headers are the same as a TRX stock (38 mm). In other words, the standard headers of a TDM are even thinner than the ones from a TRX. But I'm not sure about this.
Kayla
by Kayla » Sun Aug 02, 2009 2:27 pm
Yes, but £700 is a fair chunk more than £95...
idl1975
by idl1975 » Mon Aug 03, 2009 8:14 am
Sandy Bike Spares also do a set...
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
by cobbadiggabuddyblooo » Mon Aug 03, 2009 11:34 pm
Be interested what result you come up with Kayla.. Had a local manufacturer make up a set of big bore headers n 2 into 1 and found just on 87 horseees at the rear with the fcr's n bellmouths..
schmiffee
by schmiffee » Tue Aug 04, 2009 5:38 am
Sounds good Cobba....post a piccy
Maybe in a more suitable forum or we may get in trouble by the powers that be for diverting off topic
I would be interested to see however...
stormy
- Former Member
by stormy » Tue Aug 04, 2009 10:26 pm
Whoa!!!!
TDM headers won't fit a TRX!
The TRX engine is canted slightly further forward in the frame compared to a TDM, so the headers are shaped (curved) differently.
I've got both bikes, and tried to swap the headers over "just to see" and take it from me, they are not interchangeable. If you fit the TDM headers to a TRX motor in the TRX frame, then the outlet of the headers (which is a single outlet on the TDM, not twin outlets like the TRX) is hard up against the starter motor behind the sump. TRX headers won't even go under a TDM, as they foul on everything under the engine, left pipe wants to be where the chain is, right side hits the frame....
mike
1996 TRX850 ... gone away for a holiday
1997 TDM850 ... fully restored
1998 Ducati 748 ... it is very red
2000 Thunderace ... simply the best!
2008 Bandit 1250SA .... tis a bit dented now.... damn
TonyDevil
by TonyDevil » Thu Aug 06, 2009 2:06 pm
idl1975 wrote:Sandy Bike Spares also do a set...
dont touch the headers from sandybike spares
it took me 2 different sets to find ones that fitted and they are already rusty!
yes rusty, shite quality 'stainless' and they have cracked after a year on the bike
TDM900 2003 - commuting tool
Z750 hardtail - project
