Not quite a TRX but...
Posted: Wed Sep 02, 2009 8:17 am
by Millsy
This is my old TDM that got written off and turned into....well this!
About a dozen different bikes in there somewhere.
Happy to say I now have a proper bike,a blue '96 TRX.
Re: Not quite a TRX but...
Posted: Wed Sep 02, 2009 8:44 am
I quite like that
Posted: Wed Sep 02, 2009 9:10 am
by schmiffee
I do too...really quite nice - not too sure about the front fairing from the front, but from the side it suits very nicely
Posted: Wed Sep 02, 2009 9:56 am
by Stu99
That's cool, nice work.
Posted: Wed Sep 02, 2009 10:40 am
by gregs656
I like the front fairing
Posted: Wed Sep 02, 2009 12:26 pm
by rocket60
put me in the I like that catagory,very cool
Posted: Thu Sep 03, 2009 5:56 am
by Kayla
I like it too
Posted: Thu Sep 03, 2009 8:06 am
by Red Rex
Yep ... me too
(to get a "
" you need to fit a long, tapering, curving, up-swept megaphone exhaust tho')
Posted: Sat Sep 05, 2009 6:47 am
by Wombat
Yeah like it too. More pics!
Gives me an idea if the TRX ever goes to heaven.
Posted: Sat Sep 05, 2009 9:43 pm
by Millsy
Wombat wrote:Yeah like it too. More pics!
Well I can tell you what you will need......
1.Aprilia RS250 (1994) Fairing and Headlight with cut down side panels.
2.Aprilia RS125 rear seat fairing
3.Suzuki GSXR600 rear light and rear sets.
4.TDM mk2 seat shaved and re-profiled
5.Yamaha Diversion 600 tank,cut and shortened 40mm
6.Yamaha FZR600 front wheel and discs.
7.Racetech clip ons.
8.Micron 2 into 1 pipes and shortened can.
9.Hagon shock.
10.Gas flowed head.
11.Kent Cams.
12.TRX pistons
13.Raised compression (thinner head gasket)
14.FCR41's (fitted later from a set of 4 bought from some guy in Sweden)
15.FZR1000 forks (fitted later)
16.FZR1000 swing arm (fitted later) with shock mount cut from the bottom of the arm and re-positioned on top.This was a tricky welding job which I had a bike shop do.
I have to admit that the exhaust was loud and didn't last too long before being,literally,blown to bits. But it was good fun round Cadwell while it lasted.
Posted: Mon Sep 07, 2009 9:02 am
by DrSlumper
Great job!!!! I like a lot.
more pics!
Posted: Thu Sep 10, 2009 11:29 am
by Quan-Time
yes, quite nice.. Not convinced about the headlights tho, but other wise, VERY nice.. Im a huge fan of the tail section, very clean, with matched underslung exhaust. Huge fan of that.
Posted: Thu Sep 10, 2009 11:49 am
by TonyDevil
Millsy wrote:This is my old TDM that got written off and turned into....well this!
i think the base is a mk1(91-93) frame and engine, later model forks & yokes?
how are you finding the TRX compares?
assume you are liking the engine/exhaust noise a bit better
Posted: Thu Sep 10, 2009 10:22 pm
by Millsy
Well the older engine used to feel much smoother and easier to rev,but the gearing was also much lower in 1st and 2nd as well as the different crank of course.
My current 'Rex makes a sound to die for when coming out of roundabouts and just winding it on.
In the process of upgrading the suspension with an Ohlins rear after destroying the rear tyre on a recent track day.The front will soon follow (currently Thundercat forks) with Ohlins springs.Then R1 complete front braking system and only when that little lot is done will I turn my attention to the engine,all should be ready for the new year.
