cant get neutral
Posted: Thu Apr 15, 2010 1:08 am
by pom in nz
Hi people, need some advice on why i cannot get neutral when bike is stationary, but motor running, i can get it if the bike is moving
i have done an oil and filter change, and i have a new clutch. it seems to have got progressively worse
she has done a lot of ks and im working my way thru the bike, replacing and modifing
so any thoughts
Re: cant get neutral
Posted: Thu Apr 15, 2010 1:16 am
by ekoja
I should learn to read the bloody post properly eh.
I guess you have checked both clutch cable adjustment points?
Posted: Thu Apr 15, 2010 1:59 am
by lenny
Sounds like the clutch is dragging (not fully releasing).Does it clunk badly when you select first gear with engine running? Check cable free play. Clutch release mechanism may be worn or clutch wrongly assembled.
Posted: Thu Apr 15, 2010 5:06 am
by pom in nz
yes lenny it will clunk into first, but only when cold, when hot no clunk.
when i try for neutral, it will either drop into first, or if i come up, it lifts into second,......but if i am moving, even very slowly its ok,? its not that i can never get it just getting harder and harder.
Posted: Thu Apr 15, 2010 5:10 pm
by slow codger
drive chain not too slack!!
Posted: Fri Apr 16, 2010 11:09 am
by lenny
Another possibility. On the end of the shift drum hidden by the clutch is a star wheel. A spring loaded arm with a roller on the end (called the stopper arm) bears against the shift drum star wheel and indexes the shift drum in the 5 gears and neutral positions. If the spring which pushes the stopper arm against the shift drum is weak, broken or missing you can get this sort of problem.
