Distance swingarm-sprocket on std bike?
Posted: Tue Apr 27, 2010 10:04 am
by HansJ
As I have Marvic rims, and before that had Yam 5.5" rim, I don't have a clue what the distance is. I am about to manufacture an off-set rear sprocket, and need to know how much off-set i should go for. Thx in advance!
Re: Distance swingarm-sprocket on std bike?
Posted: Tue Apr 27, 2010 12:26 pm
by HansJ
I am fast, but sometimes terribly wrong...
I need also the inner distance between the swing-arms, if you measure with a standard swing.(I have the YZF750 swinger, so if anyone has the distance between the YZF swinger and sprocket, with a correct chain alignment, that'd be the best...)
Posted: Wed Apr 28, 2010 6:02 pm
by HansJ
Pretty please? Measurement between swingarms right in front of thhe rear sprocket, don't need an exact figure.
Posted: Wed Apr 28, 2010 8:56 pm
by Tarwetijger
I have a YZF swingarm too and I am not sure what to do with chain alignment.
Now that I think of it, I have a TRX swingarm laying around somewhere and a wheel... Hmm, maybe the best thing to do is just to put it together!
To be continued.
Posted: Wed Apr 28, 2010 9:53 pm
by slow codger
Using the yzf wheel, I just turned my standard trx sprocket round so that the dished side faced inwards.
Posted: Wed Apr 28, 2010 10:22 pm
by Tarwetijger
I did exactly the same, but the chain scrubs the YZF swingarm every now and then.
Posted: Thu Apr 29, 2010 7:27 am
by HansJ
Dished sprocket would probably work, but i have a different rim which means original sprockets don't fit. (Different centerhole, hole pattern etc). The Marvic rim might also have different hub-width, but this i don't know....
Posted: Thu Apr 29, 2010 10:53 pm
by HolerTogni
Hi Hans!
HansJ wrote:Pretty please? Measurement between swingarms right in front of thhe rear sprocket, don't need an exact figure.
I try to give you the figures tomorrow (30.04.) evening - would that be "early" enough
Future greetings from Munich!
Posted: Fri May 14, 2010 8:07 pm
by slow codger
Hans, do you still need the measurements?
Posted: Thu May 20, 2010 8:24 am
by HansJ
Thanks, but I've ordered the sprocket already. Went for 4 mm off-set, haven't received it yet so can't say if my guess was right...
Posted: Thu May 20, 2010 9:42 pm
by HolerTogni
Hi Hans!
I didn't really forgot to measure
But, hey, yesterday I realized that the distance between the arms
of the swing arm is difficult to measure with the rear wheel installed ...
Anyway, the distance from the outer edge of the left swing arm to the sprocket is (about) 18 to 20 mm (also difficult to measure with the TRiXie standing on the garage wall with a car on her left side and with no accurate measuring tool other than a folding rule - but didn't you say you wouldn't need exact figures
Belated greetings from Munich!
